3 members (55shaker, greenie-reddy, 3100RustyParts), 134 guests, and 3 robots.
Topics128,260
Posts1,058,319
Members48,485
V
V Offline
I was just installing a bunch of crap that I ordered up from Speedway. Among the crap was thrust bearing style kingpins and a disc brake. Their kit is marked as CPP's. My issue is that the bracket that holds the caliper is hitting the L-shaped steering stop bracket (it is retained to axle by kingpin locking bolt) that the spindle would normally hit. Has anyone else run into this with this kit? I figure I could clearance the bracket but I worry about removing too much meat, or clearance the stop but then I think the bracket would still end up hitting the nut on the bolt that retains the kingpin or just get rid of the stop and turn the kingpin bolt around. I'd call their tech but it is the weekend and they are closed- of course they would be at the time when the majority of people actually do their projects.
I had the same problems. Go to my 54 GMC site and click on Front Suspension. Read down for brake installation.
The problems with CPP products are legendary and you can read about them here and all over the Internet. I myself have posted the contents of a complaint to them that they refuse to answer.
LINK TO LETTER detailing the myriad of problems I encountered
Good luck, you'll need it.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
It's been some time since I installed my CPP 5 lug front disc brake kit on my 54 but if I remember correctly, the INSTALLATION sheet specified that the steering stop should be removed.
I've used a number of their products and haven't had any problems with installation. I assume they're still putting installation instruction sheets in with their products.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
