0 members (), 44 guests, and 4 robots.
Topics128,077
Posts1,056,013
Members48,433
#39524 03/29/2003 5:07 AM
I recently installed a saginaw 2-groove 4-spd in my 51 chevy 235. the slip joint on the tail shaft and the tail shaft have finer grooves than the three speed did and I couldn't use the slip joint from the 3-speed and the one on the 4-speed looked like it had the clutch popped on it one to many times as the splined grooves in the slip-joint were slightly twisted and made it hard to get the slip-joint all the way on the transmission tail shaft!! I did get it on and it works OK but I would like to get a new one. question to ya'll is where do I find a new slip joint??? Thank you.. AG-Pilot
#39525 03/29/2003 7:37 AM
check the wreckin yards for GM trucks after about 67 or 68 - just get the yoke and put on yer shaft w/ new cross - worked for me
#39526 03/29/2003 9:24 PM
Even a yoke from a TH-350 will work; same yoke eek smile . Should be an easy one to find in the "pull-your-part" yards.
*** GMC ***
