| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39524 03/29/2003 5:07 AM | Joined: May 2002 Posts: 23 'Bolter | | 'Bolter Joined: May 2002 Posts: 23 | I recently installed a saginaw 2-groove 4-spd in my 51 chevy 235. the slip joint on the tail shaft and the tail shaft have finer grooves than the three speed did and I couldn't use the slip joint from the 3-speed and the one on the 4-speed looked like it had the clutch popped on it one to many times as the splined grooves in the slip-joint were slightly twisted and made it hard to get the slip-joint all the way on the transmission tail shaft!! I did get it on and it works OK but I would like to get a new one. question to ya'll is where do I find a new slip joint??? Thank you.. AG-Pilot | | |
#39525 03/29/2003 7:37 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | check the wreckin yards for GM trucks after about 67 or 68 - just get the yoke and put on yer shaft w/ new cross - worked for me
Bill | | |
#39526 03/29/2003 9:24 PM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Even a yoke from a TH-350 will work; same yoke  . Should be an easy one to find in the "pull-your-part" yards.
*** GMC ***
