1 members (1 invisible), 116 guests, and 3 robots.
Topics128,193
Posts1,057,258
Members48,466
OK, I just installed the new coil (with internal resistor) and a rebuilt distributor. I found TDC with no problem, and the engine fired right up. But, I couldn't get it to idle at all. I adjusted the idle screw, but still no idle. But I did notice white smoke coming out of the carb when the engine was off. Is this what I think it is? Head Gasket failure? eek :mad: frown :confused: :mad: frown :confused: :mad: I didn't notice any sign of water in the oil. hmm......
Steve
There are no symptoms that you described here that point to a head gasket. Burning antifreeze produces white smoke out the exhaust. If you mean it won't stay running at lower speed, I would guess that you might have a vacuum leak. This is quite possible after disturbing the distributor. You could have a cracked vacuum line.
1951 1 Ton Completed
Junior Member
Junior Member
White smoke comming out the CARB? Not the exhaust? No idle? I would look at the linkage. If the linkage is stuck and you play with the idle screw, it will have little effect. Also, when you turn it off the extra gas can cause a white cloud to come from the carb.
hr41pearl cool
Tab Offline
sounds like the carb is running rich.
delete my account and pictures
It sounds like you have the float set too high and the bowl is overflowing down the carb throat. The white smoke is fuel vapor.
Paint & Body Shop moderator
