5 members (Nuts&Bolts, Joe H, baldeagle, Shade Baby, dt235sd), 66 guests, and 1 robot.
Topics128,014
Posts1,055,331
Members48,419
#39505 10/21/2003 5:18 PM
Howdy,
Anyone know the differences between a 3/4 ton standard and 1/2 ton spindle on a 41-46 Chevy?
Do any of the parts interchange between the two axles?
Looking through my 41 manual it looks like the front section of the chassis are identitical on the 3/4 ton standard and the 1/2 ton. If the parts don't interchange it would seem like an entire 1/2 ton assembly could just bolt on to a 3/4 ton?
#39506 10/21/2003 8:20 PM
Parts manual shows a different part number for 1/2 and 3/4 ton axles 41-46. The steering knuckle shows same part number for 41-42. Different part numbers for 46-47.
#39507 10/21/2003 10:12 PM
hey thanks Ralph, Rusty46,
so it sounds like I might have a chance then! I am going to do some measuring tonight and check out that manual some more. maybe if I post some pictures one of you 1/2 tonners out there can help me do an online comparison.
_Eric
#39508 10/22/2003 2:22 AM
Hello Eric
If you need measurements or an axle, I have a 42-46 3/4 ton axle with steering knuckles laying on the garage floor.
A good source for axles is your local restoration/hot rod shop.
#39509 10/22/2003 11:56 PM
Thanks Rusty, I will let you know if I need anything!
hey next summer I forsee the need for a "stovebolt northwest" convention. lol
#39510 10/23/2003 1:11 AM
A Stovebolt NW event could be a good thing. smile
