9 members (cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible), 109 guests, and 4 robots.
Topics128,062
Posts1,055,847
Members48,428
#39494 04/13/2002 10:42 PM
Sorry if this doesn't have to do with stovebolts but hopefully someone can help me out. I just bought an '80 buick lesabre for a demolition car. It has a recently rebuilt small block(non-original) with a rochester 1 barrel carb. The guy I bought it from thought it was either a 350 or 307, but wasn't sure. Does anyone know what this engine could be? It just looks like a typical chevy small block but I've never seen one with a 1 bbl carb before. Thanks.
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#39495 04/14/2002 12:17 AM
Red dot, center of chest ...
The only 1bbl carb V8 GM ever made was in 1933. I can't imagine that a 1bbl Rochester could even keep a V8 idling, much less get something moving. Small blocks came with 2bbl and 4bbl Rochesters.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#39496 04/14/2002 12:31 AM
Well now I'm really confused. I am 100% POSITIVE this is a rochester 1 bbl and a GM small block. Anyone?
Rollin' Hard
1946 Chevy 1/2 ton
1959 Phord 1/2 ton
2001 Chevy 1/2 ton
#39497 04/14/2002 1:02 AM
I've seen those in junk yards. They were in light commercial trucks. You need to find the casting numbers to ID the size.
if it dosen't need fixed, break it
#39498 04/14/2002 7:32 PM
Oly Offline
Paul is very correct on this one. One barrel Rochesters are on sixes, but I seem to recall something like what you are speaking of but would bet that that carb is a two barrel. I will say- anything is possible- but a one barrel on a V8? Not good. Why would you do it? Get some numbers off from the motor and the carb. We can help you more with that info..
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#39499 04/15/2002 6:18 AM
Well, the Rochester 2-jet has the same inlet size as the one barrel "B", and is smaller externally than a Holley 2bbl. What's the intake look like?
6 > 8
-Keepin' Things Inline-
