4 members (cmayna, baldeagle, Gray_Ghost, Phak1), 80 guests, and 4 robots.
Topics128,017
Posts1,055,338
Members48,419
#3943 05/09/2003 2:16 PM
Kip
Offline
'52 Chevy P/U. I have drift side to side. When parked the steering wheel feels fairly tight. But when driving there is some drift. Where to check first? 1.Steering Box (side adjustment or bottom front adjustment of box)? 2.Tye Rods? 3.King Pins?
Thanks and Adios, Kip
Write On The Cross At The Head Of My Grave
To Whiskey And Women Here Lies A Poor Slave
#3944 05/09/2003 3:07 PM
If you can slide under the truck, have someone move the steering wheel from side to side, enough to get past the play. Look at everything that is moving and better yet feel it with your hands. Are both ends of the drag link and tie rod end tight ? Is the steering box tight against the frame ? Try to identify any worn parts.
Jack up the truck and put a bar under each tire. Is there any up and down or side to side movement ?
When was the last time your toe in was checked. A poor adjustment there can make the front end wander.
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#3945 05/09/2003 4:35 PM
534me makes a good point about the steering box being tight against the frame.
I bought a 71 C-10 and when I first got it, I was turning the wheel twice and steering once, all the way down the highway. I thought, the heck with this, I'll rebuild the front end. I did everything, springs, shocks, tie rod ends, pitman arms, balljoints, upper and lower control arm shafts, the works.
I thought, now I'll take the test ride that will show me how this truck is suppose to steer. smile
Well, I started down the road, and I'm still turning twice and steering once frown :confused:
Back to the garage, started checking things out, and found the mounting bolts, for the steering box against the frame were loose. Tightened them up; took another test ride and smile smile smile Just like new !
Joe - (Buckeye Bowtie)
"Remember it takes about 2850 bolts to built a Chevy Truck and only 1 NUT to scatter them all over the highway"
1950 3100
1971 C-10
1939 Buick Century
#3946 05/09/2003 7:03 PM
It sounds like you have bad king pins, mine felt tight when it was sitting still but were very loose. Also get it aligned when you replace them, it makes all the differance in tracking once you get everything tight.
Paint & Body Shop moderator
#3947 05/09/2003 7:33 PM
kingpins loose enuff to do it should be easy to find in wheel play, but I vote for the toe adjustment - little off makes a big diff in tracking - been there myself just recently
#3948 05/10/2003 12:59 AM
Don't forget the castor wedges .
#3949 05/10/2003 8:04 AM
Kip
Offline
Thanks Hermanos! It's lookin like an alinement problem. I'll check back later.
Later On and Adios, Kip
