0 members (),
125
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 27 Apprentice | | Apprentice Joined: Dec 2007 Posts: 27 | Could I use 1/4 inch stainless tubing for all my brake lines on my truck? Any info on this would be greatly appreciated.
Wanabe Mechanic
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This was covered not to long ago in another thread, but this is what we have determined. !/2 ton short bed uses 3/16" for all lines, 1/2 ton long and up uses 1/4" for all lines exept for the rear axle line, which is 3/16". It would be best to use the correct size for the truck.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | jk55boy What are you working on? Are you going to upgrade brakes? Will you be using a booster MC? If so then the original size line requirement goes out the window.
~Jim
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | As mentioned earlier there are standard sizes for various models but the important thing is to match the brake line size with the components on the truck. If you are going to use the original rear wheel cylinders and they have 3/16 fittings it wouldn't make any sense to try to adapt 1/4 lines. If you are using a later rear end and it uses a different size line, you will need to change accordingly. Fred
| | | | | Joined: Dec 2007 Posts: 27 Apprentice | | Apprentice Joined: Dec 2007 Posts: 27 | I plan on either using a 12 bolt rear end or a camaro rear end if I am able to find one reasonable. On the front I am puting mustang 2 stock size disc brakes. I have the power brake setup that fits in the stock location with a 7" booster. The reason I want to find a camaro rear end is because I am getting my front rotors with 5 on 4 and 3/4 bolt pattern.I use 1/4 " tubing at work on pneumatic controls and was wondering how hard it would be to find fittings to adapt.I will need to find aflare tool also. thanks for all the info
Wanabe Mechanic
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | You can use 1/4" lines. I have a 10 bolt Camaro with 12 disc brakes and I am using 3/16 lines. http://good-times.webshots.com/photo/2540282850099708909YZvPCmI use a Snap-on flaring tool but you can find them at Northern Tool or Harbor Crap freight. BTW the 12 bolt you are talking about is a later Camaro/Firebird rear. The 10 or 12 will fit depending on what year truck you have.
~Jim
