0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
#3941 09/04/2004 11:47 PM
Junior Member
Junior Member
I have a 54 3100 with a 230 and a Muncie 22 tranny, the m-22's third gear is trashed and one ear is broken off, any suggestions, a local shop quoted me $750 to rebuild but won't touch it with a broken ear at the bell housing.
Someone has told me that a Borg Warner Super t-10 is a direct swapp for the M-22.
Will a t-5 bolt up, would I need a new bell housing, clutch ect?
What about a SM-40 or 45 from a 60's truck ect?
Want to get out as least exspensive as possible, cause I am going to eventually rebuild the 235 and 4 speed to put back into, within a couple of years.
Thanks again for all your input
http://community.webshots.com/user/flightrn54
#3942 09/06/2004 12:49 AM
New parts can be had for the muncies, even cases, online. Broken ears are a common problem. They are pretty easy to rebuild. Otherwise, you can replace it easily with a Saginaw box. One thing, though, if this is a real M22 rockcrusher box it is worth quite a wad of cash.
Paint & Body Shop moderator
