4 members (Otto Skorzeny, Peggy M, Lightholder's Dad, 1 invisible), 101 guests, and 3 robots.
Topics128,026
Posts1,055,409
Members48,422
#39400 10/05/2003 2:03 AM
my 1955 GMC 1/2 ton automatic has a 248 motor with a piston blown out the side.
what motors came stock in 55 and will bolt in ?
Is the 248 a good motor to stay with?
thanks for any information
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
#39401 10/05/2003 4:16 AM
chevys had 265 v8 or 235 six
if you wanted to stay GMC probebly would have to go with poncho engine dont know witch one would be stock
248 is a good engine but if it has a hole in the side of the block from the piston not much you can do expt keep the crank and head and outher spare parts
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#39402 10/05/2003 10:52 PM
You might look for a GMC 270 or 302. Both will look very similar to your 248 and should bolt up like they were put there by the factory (unless you get a military 302, which does have some differences).
I have a 270 in my 55, which came stock with the 248. Unless I tell someone, they can't tell without checking the casting or serial numbers.
#39403 10/06/2003 1:27 AM
thanks for the information No bad news about 248 will most likley stay with it, 302 or 270 I will check into that some more . Old hydromatic may not want much power thanks Bill
#39404 10/06/2003 1:36 AM
Are we talking second-series 55? If so, they came with small V8s stock. One will bolt in, but you do need to change the bell housing as well as the motor. The hydramatic would take the power if you don't build a hot-rodded V8.
George
#39405 10/06/2003 2:23 AM
That Hydra-Matic will easily handle the 270 or the 302.. The 248 is a nice motor as well. Keep a Jimmy motor in that Jimmy ...
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#39406 10/06/2003 6:08 AM
The hydromatic was used behind the V-8s used in some pickups and cars. I once owned a '57 Pontiac with a 347 and a Hydromatic. That some combination was used in GMC pickups at the same time.
