10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 16 New Guy | | New Guy Joined: Mar 2008 Posts: 16 | I traded a 1968 falcon, for this thing, realizing the falcon would never really be worth what it would cost to fix it, and wouldn't be quite as fun. Pictures The engine runs great, had to replace the fuel bowl gasket so that it would keep gas. So far I've purchased the floor pans, cab corners, and other cab parts, I'm in college so it will have to wait until the summer to get anything major done to it. I do have a few questions: The guy I got it from said it had a 2-speed rear end, I'm not convinced it does as there are no levers or anything going to the rear end that would make it one. I'll have to get some better pictures. I'm fairly certain it is a 1953 6400, with a 235 And while I've been browsing around, what does COE stand for? Thanks.
| | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Welcome to the Stovebolt Colossal. Awesome trade for a Falcon.I'm almost sure you have a 2-speed rear, I can't tell from the pictures though. There should be a small round switch on or just under the dash that says low/high on it. COE means "cab over engine" you've seen them around, real stubby looking but highly desirable.N
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Another Welcome to ya, and that's a good look'in truck, you have there. If it's a 2 spd. rear axle, it will have a diaphram bolted to the left side of the hogs head, facing the front of the truck, with vacuum hoses attached to it. It will also have a round lever actuated swith mounted below the dash between the steering column, & ignition switch. If you want to see what a COE (cabover engine) truck looks like, click the link below. | | | | | Joined: Mar 2008 Posts: 16 New Guy | | New Guy Joined: Mar 2008 Posts: 16 | I'm fairly certain that it doesn't have the diaphragm, I have my dad taking pictures and emailing them to me soon though to confirm, thanks for your help. Is there a way to tell by the VIN number if it should or shouldn't have came with one? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A 2 ton AD (Advanced Design) generally, but not always, came with 2 speeds. It's the 1.5 tons that were standard with a single speed rear but a two speed was an option. This is the vacuum valve/switch for a two speed: http://rides.webshots.com/photo/2662657990080251109jBhLTFI don't have a picture of a two speed rear handy, just checked. Grigg | | | | | Joined: Mar 2008 Posts: 16 New Guy | | New Guy Joined: Mar 2008 Posts: 16 | Mine doesn't have that switch, may have had it and gone now, the wiring is a jumbled up mess with all the add-ons that were done to it. I've seen the diaphragm here on the site, and am fairly certain that it doesn't have it, but I'm getting the picture to confirm. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 |
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Hey -- quit showin' people your rear end! This is a family site!!
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Purely for education purposes only. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 |
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Hoo - Ra! (That is right - isn't it)  Correction: Hoo-Ya (It's at the top of the page)
| | | | | Joined: Mar 2008 Posts: 16 New Guy | | New Guy Joined: Mar 2008 Posts: 16 | RearendSo, it's not a two speed...disappointing. But moving on, how do you bleed the brakes, is it just like any other car, I've tried it, and that didn't work. And what does the big cannister thing do in the brake system? Thanks for everyone's help thus far. | | |
