2 members (Buckeye998, TUTS 59), 338 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
#392819 03/25/2008 4:08 AM
Apprentice
Apprentice
1 Offline
gentlemen,
Can you give me the simplest way to adjust the valves/lifters on a 39 216 engine? They have the screw driver head above the push rod with a bolt to lock it down. Is there a gap size for the rocker to the valve stem?
1fine39
Here's one set of instructions, with gap (lash) settings.
There is a somewhat similar set of instructions in the Tech Tips section of this website.
Here is another very good set of in...r hydraulic lifters in 235/261 engines).
Apprentice
Apprentice
1 Offline
Found them, thanks
