2 members (DennisM, 1 invisible),
80
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 7 New Guy | | New Guy Joined: Feb 2008 Posts: 7 | I am trying to install speakers in the original location under the dash of a 1965 C-10 fleetside. I have custom autosound speakers that they say will install in stock location. But I can't find anywhere to mount it. I don't think the truck had a radio originally so probably no speakers. Does anyone have any ideas how to mount the speakers?
| | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Well, there should be a slotted section on the dash. IF so, what I did was get some thin gage strips of either aluminum or steel and cut some home made brackets. I just used some cardboard to make a template and it worked out OK. Then I also made sure the brackets could accomodate hanging the radio since the back side needs it. It's not fun working on your head but with a little patience and trial and error it was solved. Gary
GS
| | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | Yeah that sounds about right for working under dashboard. Get inverted, crawl in, and stay til the job is done....
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Feb 2007 Posts: 435 'Bolter | | 'Bolter Joined: Feb 2007 Posts: 435 | Hey folks. Don't give up. I'm working on a 63' for my Sis with a sizeable jukebox in it(long ways from a stocker, 350/4speed,4:11 rear.) And under the dash is a mount like you're talking about already made. As soon as the new harness gets here next week, I'll pull it out and take some measurements and some pix. | | |
