1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
Junior Member
Junior Member
Can a cast iron 4 speed saginaw work ok in 1950 chevy pickup with a small V8 (350)? Or should i say is it recomended? In other words what would be the best choice? for a 4 speed. Thanks in advance.
You can use the car 4 spd. Saggy box; just don't do burn-outs, side-step the clutch or get heavy with the throttle...........they die easily. I know, I have killed several of these when I had a car..........Man, it was fun though grin
Watch for the grooves in the input shaft, the tell you what gear ratios are inside.
I have a list here, but I am too lazy to type it in (hardcopy only).
How many grooves on yours, or do you have one yet?
*** GMC ***
