3 members (Otto Skorzeny, MNSmith, Gray_Ghost), 63 guests, and 1 robot.
Topics128,057
Posts1,055,812
#392228 03/24/2008 2:32 AM
Has anyone mounted a radio behind the speaker grill in a
AD truck? I was thinking about welding the top and bottom trim to the grill and using a small piano hinge and and a glove box hinge to flip it down. I figure with some speaker cloth in the grill you won't be able to see the radio. I have an extra grill to play with. Any ideas?
Thanks Neil
Neil,
Im mounting mine behind the glovebox door,I purchased a new lock & pushbutton, Im sure your idea will also work with some fabrication.
Tim
1952 Chevy Shortbed
Photos in Photobucket
I just hate wasted space and the speaker hole is just wasted space. I may mount the radio in the glove box and put a small insert in the speaker hole to hold CDs and other small stuff out of the line of sight. I think I can make the flip down door bolt to the lower origional mounting holes and put some rubber bmmpers in the top holes.
Thanks Neil
Wherever you put it you might consider a radio model with an infrared remote and get a remote extender. That way you can mount the radio anywhere and just point the remote in the direction of the extender tip for operating functions.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
I mounted mine behind the seat of our 53. We use a remote control. We built a box with speakers and the radio mounted in the box.Wife covered it with vinyl to match our battery box and valuable box all behind the seat. I have some photos of it on the page at the bottom if you want to see what it looks like
Not if you put speakers there. Speaker placement is probably more important than deck location for a good sounding setup.
http://rides.webshots.com/photo/1377797155023244788NFaLVF
You Tube
I agree Curt, I have speakers behind the seat and behind the speaker grill. Sounds great!!!
I was looking upper kick panels for speaker mounting. I have alot of time to think about it while I do the other thousands of things I have to do first. Unless I want to sit in the garage and listen to the radio and make motor noises. I was just wondering if anyone else had used that area for anything else. It was a great location for a speaker hooked to an AM radio. You can get great sound from good speakers even that close. Most of my radio listening consist of PRM news and talk shows. Not the most demanding audio content.
Thnks for the input
Neil
Moderated by  ndkid275, Phak1
