| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 19 Apprentice | | Apprentice Joined: Feb 2008 Posts: 19 | Hello,
what would be the easiest way to convert my 1951 chevy 1 ton to dual wheels?
Ryan | | | | | Joined: Mar 2008 Posts: 3 New Guy | | New Guy Joined: Mar 2008 Posts: 3 | If you lived near Fort Worth I'd say the easiest way would be to swap me your axle. I'm converting my '51 1 ton flatbed to a pickup bed, which means I'm going to have to also swap the dually axle with a 1 ton single.
Were you wanting the keep the same ratio on the new one? I believe 1 ton duallys came with a 5.14.
Dave
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | If you want to run dual wheels on the front you need dual type front hubs. The original wheels would be hub-piloted 18 inchers.
I have a '54 GMC 1-ton dually and can look at it to answer questions for you if you like.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2008 Posts: 19 Apprentice | | Apprentice Joined: Feb 2008 Posts: 19 | I want to run the same gears as my truck came from the factory with 5.14 gears, I would like to swap out to the proper parts for my year,
my father drives semi and in in texas alot so maybe we could work out a deal.
I need to find front and rear axles and 6 rims.
Ryan | | |
