| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#39204 05/11/2005 12:22 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | The 41 has the original 216 with a Carter W-1 carb. I seem to remember an old post where Carbking recommended a Carter YF model 964S as an update. Just wondering if any of you guys have done this and if so how much of an improvement was there over the W-1.
My carb needs to be rebuilt so I'm considering updating to a YF.
Bob | | |
#39205 05/12/2005 2:23 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Just bumping this up to the top of the list again folks
Cheers
Bob | | |
#39206 05/12/2005 1:17 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I don't know much about them, but I've heard that the YF was a popular carb for the 235. Don't see why it wouldn't work on the 216. I've just recently gotten an auto choke YF to replace the Rochester B on my 235. We'll see how it works.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#39207 05/12/2005 3:36 PM | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Watch the bolt-to-bolt distance. My old 235 had an older Carter W-1 carb on the manifold. A Carter YF 2100 has a larger separation. Carbking did start a definitive thread on the YF including the bolt-to-bolt distances. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
#39208 05/12/2005 11:44 PM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Tim and Wally,
Thanks for the input guys. I'm just trying to get the old truck to run as efficiently as possible.
Cheers
Bob | | |
