1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 56 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 56 | i have ordered a new trailer to haul my treasures on. it will be hauling and loading from 3100,s to 6400,s. so what would be a good brand of winch and what #,s of pull? believe it or not but some of the stuf i have and find to haul home does not run and may be settled in the mudd a little. lol thanks for the help.
http://www.flickr.com/photos/11977495@N06/sets/ 1952 COE 1952 3100 1953 3100 1950 6400 1951 Suburban
| | | | | Joined: Feb 2000 Posts: 6 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 6 | I've been hauling junk cars for a couple of years now that scrap metal has been so high. I pull a 18' car hauler with a Warn 8274 double lined. I pull a lot of cars that don't have any wheels and some have the axles buried. Two things I can recommend are a good hot battery and a good bumper jack. The life of the winch is the battery and the double line helps that out and if you can get the axle out of the dirt(bumper jack) it will help the life of the battery as well. I mounted the winch as high as possible on my trailer to give the "lift" factor when pulling. Hope this helps. Btw, I've never went to get a vehicle and left without it!!
GOD is good, ALL the time!
| | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have a Ramsey model RE-12000 (12,000 lb cap) mounted to the front of my 53 wrecker. As mkmiller stated, a good hot battery (or two for lots of amps) and a good snatch block for a double line will help you out. Check out www.awdirect.com .They have good products and they will stand behind them. Stay away from the cheap China junk.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | | Houston54 Unregistered | | Houston54 Unregistered | If what you will be winching are rollers then a Superwinch 4500 should be more than adequate and does not weigh a ton as some of the heavier units do. There are pics of the installation of my Superwinch 4000s on the following link. It is not a recover type winch but if it rolls it will pull it up with little effort. http://www.picturetrail.com/gallery/view?p=999&gid=17487588&uid=2902753 | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Houston54, nice set up. That trailer is low for easy loading and transporting. The deck of my flatbed is 4.5 feet high and can be a problem at times.
| | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | For what it's worth, a few years ago I got to the point where I was sick and tired of fighting with come-alongs so I treated my self to setting up my trailer right. here are a couple shots of my set up It's a 9,000 lb Superwinch that I can mount on the front of the gooseneck with a receiver hitch I had my Mennonite welder neighbor install for me. Heaviest thing it's pulled up on the trailer is a dead '50 Mack pumper truck. She creaked and groaned, but she got it up on the trailer (I used the snatch block!). Moving equipment for my Mennonite neighbors has more than paid for both the winch AND the trailer. John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | |
