| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | There was another topic on here where an individual mentioned checking a speedometer cable a drill. This sounds like an excellent idea and I may need to try that since my speedometer does not work.
However, before I go that route. Is it possible for a speedometer not to work but have the odometer function fine? Thats my situation. The odometer continues to clock miles all while the speedo sits at zero. Does this sound more like an instrument issue versus cable?
The other question is, if you do pull the cable from the trans, do you need to be prepared for gear lube to start seeping out of the trans. Thanks. | | | | | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 |
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
| | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | 'Yes' to the odometer working but not the speedo?
'Yes' to the instrument issue versus cable?
Or, 'Yes' to the gear lube leak?
Thanks! | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Iv'e removed many speedo cables from trans. & never had any grease come out other then a few drops that have accumulated at the connector. I agree with the other 2 questions. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the odo works, the cable is fine and the trans is turning it, no need to disconnect that end - wouldn't leak anyway unless you drive with it off, and then it would be minimal - the speedo is the problem, and that could be a number of things, time to pull it apart  Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | As a teenager working for the Ford place back home, I would have to run mileage back from time to time. We used a drill and had to run it forward past 9999 miles to 8 miles. Just thought I'd add this to the discussion...
~Jim
