2 members (delky, Steelonsteel), 235 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
i need to remove the seat frame to get to gas tank to replace it.can't see how it is bolted in
Very simple,If you have the stock seat.There should be four nuts that are under the bottom seat cushion,(the bolts are welded to the sliders)remove them ,then just lift it up and out.
Moderated by  ndkid275, Phak1
