5 members (MickeyP, Cosmo, wilbur53, Bill Marlow, 3B), 158 guests, and 0 robots.
Topics128,049
Posts1,055,549
Members48,425
#39078 08/05/2004 8:56 PM
OK, I remember seeing this posted once, but at that time I did not have this problem and did not pay attention.
So, I need someone to refresh my brain.
On the 235 HP engine, my oil pressure starts out at about 14psi cold, then, when I drive it for 20 to 30 minutes, it falls to about 3 - 4 psi.
Is this normal??????
Then, next day, we start this process all over.
Help!
If at first you don't succeed . . .
er . . . then skydiving may NOT be for you!
1946 Chevy 1.5-Ton Flatbed Completed
1946 Chevy 1.5-Ton Just getting started
#39079 08/05/2004 9:04 PM
Is this a dipper 235 or a pressure 235?
3-4 seems a bit low for the dipper engine, I think at least 8 is good for that engine.
The pressure 235 needs at least 20.
Paint & Body Shop moderator
#39080 08/05/2004 10:53 PM
If it is the dipper engine, it should be up around 14 or so at higher revs. At idle it can get down below 7 lbs. When it is first started, the pressure will be higher for maybe a minute or so. That is until the oil warms up.
1951 1 Ton Completed
