2 members (TUTS 59, 1 invisible),
120
Mod | | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38963 10/17/2003 2:12 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey guys
My new 235 smokes at idle and when leaving a stop. Doesn't smoke running down the road, or when cold. Engine has 600 miles on it and runs great. Umbrella seals on intakes, total seal moly piston rings.
WTF?
Chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#38964 10/17/2003 2:34 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Maybe you got a case of bad ring seal from a "driveway engine breakin"and the cylinder walls glazed? Maybe the oil rings were installed improperly?Generally the symptoms you describe are from loose guides, but the seals should mask the guide problem if there was one.However, rings can also cause smoke like that.Although the cranking compression is good, the rings can fail to seal properly when the engine is running. Excessive bearing clearances may throw too much oil on the cylinder walls for the rings to deal with, your oil pressure is ok, right?Are you pussy footing around with the new engine? Run it harder, see if the problem lessens.If all else fails,I recomend a Latino woman,good wine and a twister,things will be better in the morning. | | |
#38965 10/17/2003 3:16 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | What color is the smoke? Black? Blue? Whitish? I'm suffering a little cylinder wash down. You can smell a tinge of oil at the exhaust. I plan on adjusting the float tomorrow and changing the oil (some fuel in the oil). Will post results. Chiphead hopefully you can cure this smoke (whatever the origin) without a major teardown (AGAIN) -ftyler | | |
#38966 10/17/2003 3:25 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Chip - Them's smoke signals being sent to you be Chief. I assume you've tried your tin-foil beanie and found it didn't work with smoke signals. It will take a while, but I will get you a translation by the end of the day.
Fred 52 3600 69 C-10
#38967 10/17/2003 7:23 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | OK, now it gets stranger. I'm looking at my exhaust pipes, and I see steel wool. Yes, there's steel wool-like metal in my exhaust pipes, stuck to the oil residue! Is this from my smitty mufflers or what?
#38968 10/17/2003 7:27 PM | | Anonymous Unregistered | | Anonymous Unregistered | If I had a TV, Chip's life with his 235 would be the show I would want to watch.  | | |
#38969 10/17/2003 9:24 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yeah, "who wants to marry an obsessive gearhead". Only problem is I haven't found any contestants.
My friends and I have joked about me and Gary getting an automotive show on public access. So far I've got one episode, but it plays over and over and over.....
We've also talked about getting our circle of friends on Jerry Springer, the title would be "which of my wives are you sleeping with, and why is my sister answering your phone?" But that's a topic for another time....
Back to the problem: Why is my car smoking? Is this why proffit was knocking the total seal rings? But the shop says they've had good luck with them. Could the metal shavings from the oil pump failure have damaged the valve stems or guides in 100 miles?
chip
#38970 10/17/2003 9:40 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The steel wool is from your smittys.
I guess you could test the valve seals by temporarily plugging the oil flow to the head and see if it still smokes.
I'm surprised you still have friends, with that curse you have. :rolleyes:
#38971 10/17/2003 10:07 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Did you receive break-in instructions with your rings Chip ? | | |
#38972 10/17/2003 11:09 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Rusty,
good points, I've been meaning to dig out the ring instructions and check installation and break in procedure.
thanks!
#38973 10/18/2003 2:09 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you get a big cloud after pulling away from an idle, this is a classic valve guide/seal problem. Rings will produce their smoke when you rev it. | | |
#38974 10/18/2003 3:57 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | You used some funny rings. They are probably taking their time breaking in. I would just put some miles on it and watch oil consumption etc. In other words, just shut up and drive...
54 3100 with 235 62 flatbed dump C60 with 261
#38975 10/18/2003 4:07 AM | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Is this the same muffler you had on the last engine? It could be ful of oil and what you see is still burning out of it. The steel wool is the packing material, try changing the muffler. | | |
#38976 10/18/2003 7:30 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I have now been able to interpret the smoke signals. They say: Sell all your vehicles and tools. You need to return to a simpler life where you have no vehicles more powerful than a bicycle.
#38977 10/18/2003 10:32 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Chip my son, my son: What am I going to do with you!! Knowing 235's yes I have rebuilt a few, your impatience is going to drive you nuts!! Drive it for awhile, check the oil, break it in right. Sounds like the smitty's let loose just a litttle from the oil of the past engine. Give it time. Break it in eaaaasy.
I wonder if we can get Ding Dongs to advertise for The Chiphead and 235 SHOW. Please don't go on Jerry Show, Maws has enough bad habits let alone waiting to see you on TV. popcorn The Truth is Out There (Thats why I use 350's) | | |
