| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38947 12/01/2001 7:54 PM | Joined: Dec 2000 Posts: 20 Member | | Member Joined: Dec 2000 Posts: 20 | where do i look on the rear end of a 1964 chevy 1/2 ton fleetside for the letters/numbers that tell the gear ratio? I have found these:3838227 GM6 :confused:
Philip Bland 1961 Chevy Apache C-10 Shortbed Stepside 235 ci 1964 Chevy C-10 Custom Shortbed Fleetside 350ci Bedford,Ky
#38948 12/01/2001 9:11 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1964 Chevrolet Truck - Rear Axle Identification
My book says that it is stamped (not cast) on the forward side of the left axle tube near the carrier housing.
It should be a code that looks like:
WF 01 23
WF = 3.07:1 ratio (in 1964) - there are 9 different codes for the 1000 series (in 1964) 01 = January 23 = 23rd day of the month
Good luck, Tim | | |
#38949 12/02/2001 1:55 AM | Joined: Dec 2000 Posts: 20 Member | | Member Joined: Dec 2000 Posts: 20 | thanks tim, I was looking in the place that i found it on my 61 model. philip
#38950 12/02/2001 5:27 PM | Joined: Dec 2000 Posts: 20 Member | | Member Joined: Dec 2000 Posts: 20 | Ok I found the numbers and letters and they are WA 11 04 and that means a 3.73.1 nov 4. they seem to be a little low for the 350 with a th350 auto,maybe i need to get the next higher gear setup.have you guys tried anything diff for the gearing? PS.is there a way for me to ckeck if it is really a 3.73.1 without taking the inspection cover off, ie;turning the wheel and count the driveshaft turns? the reason i ask is it has a crome cover on it now and maybe the guy before me changed the gearing and made it something diff from factory.
[ 12-02-2001: Message edited by: Philip ]
#38951 12/03/2001 2:00 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | Philip, Raise the rear tires off the ground, shift to neutral, rotate driveshaft and count how many times you have to turn it to get the tires to rotate once. Put a chalk mark on the tire to make it easier to watch. Make sure both tires turn, or the only tire turning will turn at double speed of the ratio.
As for gearing, I am running a 3.07 ratio in a truck with a 305/350 combo. It had a 3.9 previously. The rear end was free, or I would have gone for a 3.5 or 3.3. It is definitly no rocket ship, but it gets much better mileage and fits my driving style/conditions better. | | |
#38952 12/03/2001 2:07 AM | Joined: Dec 2000 Posts: 20 Member | | Member Joined: Dec 2000 Posts: 20 | Thanks Curly, I'll give it a try tomarrow. Phil
