1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I'm fixing to mount a three speed Brown Lipe in my 46 1.5 ton Chevy. Should it be bolted straight to the frame or insulated with rubber pads. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Some sort of rubber pads would be best. Most all the factory installed auxiliary transmissions I have seen have some sort of cushion mount. You may find this Tech Tip helpful with setting up your drive-line angles. http://www.stovebolt.com/techtips/driveline_setup.htmlGrigg
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Thanks for the reply. The mounts that came with the brownie suggested that it was mounted solid which looks like an open door for problems. The tech link didn't work but I think I can do the shafts and angles with no problem.
Tony | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Try the link again, should be fixed now.
I expect it would be OK solidly mounted, but be quieter and kinder to the frame and mounts if it is somewhat flexible. Either way probably fine..
Grigg | | | | | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Hi ttodd. I would suggest installing your aux. transmission with rubber pads. As Grigg says it will be quieter and easier on the frame. Here is a picture of how I did mine: http://good-times.webshots.com/photo/2236843520099958186JSAynsIt's a little hard to see, but there is an angle iron bolted to the frame that the rubber pad sits and bolts to. Then the aux. transmission mount has an angle iron that sits and bolts to the rubber pad. There's lots of ways to do it depending on the type of pads you have. But haven't had any trouble with this setup. Also just a side note. I mounted the aux. trans with the rear yoke right where the carrier bearing used to be. That way you don't have to redo the back half of the driveline, you'll just have to shorten the front half. Good luck and hope to see some pictures, Paul.
1948 Chevy 6400 1964 Chevy 1/2 Ton
| | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Not sure what your front mount is, but the rear would be two ears that would pad mount to a corisponding bracket, these mount solid, the front might be a yoke type bracke and it would have a rubber V Belt around the inside of it where it contacts the trans, it too would be bolted solid to the frame. | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Got some rubber body biscuts and some 3/8 X 2 X 2'' angle iron gonna mont it this week end. Planning on taking the old truck "Ralph" to Hutchinson Kansas truck meet in May, hope to see some Bolters there.
Tony | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | One precaution, if you're not aware of it already, but it's a little risky to drill holes in the frame flanges to mount your brackets for the Brownie. Fabricate a 90 degree angle at the ends of the angle iron brackets that's a close fit to the inside of the frame rails, and drill bolt holes in the vertical section of the frame. That's how we mounted auxiliary transmissions on the big rigs I used to work on. Drilling the flanges, particularly on aluminum frame rails, creates stress risers that can break a frame in two across a drilled hole. Jerry
