1 members (Otto Skorzeny),
81
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38928 11/29/2003 7:01 PM | Joined: Jul 2003 Posts: 10 New Guy | | New Guy Joined: Jul 2003 Posts: 10 | After cleaning the distributor, I can not find the bakelite washer for the grease port. Is it necessary if you remove the spring? I assume the purpose of the spring is to act as a locking device so the grease cap can't vibrate loose. i am afraid the spring will wear on the shaft but if i dont use it and use locktite instead will it work? thanks in advance | | |
