0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38902 11/20/2001 2:41 PM | Joined: Jan 2001 Posts: 14 Member | | Member Joined: Jan 2001 Posts: 14 | I need to replace the bushing in the rear of the transmission that is the outer support for the front of the universal joint. the transmission is a 3 speed on the tree, serial # LO 72823. what is the procedure to replace this bushing? I was told by one of our suppliers that there is a external bolt that holds the collar containing the bushing, but there is no external bolt visible. anyone done this with out removing the tranny and disassembling it???? HELP! | | |
#38903 11/21/2001 3:50 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I replaced one of those bushings once. The only way I know of is to remove the tail housing. Dropped the tranny, disassembled, replace the bushing and put it all back together. Took about half a day. I was younger and stronger then, could remove and replace the tranny by myself with no jack back then  , now I have to use a jack under the tranny.
Fred 52 3600 69 C-10
#38904 11/22/2001 5:59 PM | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | The retaining plug (the bolt you speak of) is at about 1 or 2 o'clock looking at the end of the transmission. Then the trick is to get the bushing out, I hope you have the transmission out of the truck, it is easier that way. | | |
