4 members (1955 1 Series, Thomaslb, 52Carl, Hotrod Lincoln), 106 guests, and 2 robots.
Topics128,090
Posts1,056,031
Members48,433
#38851 07/09/2002 8:02 PM
I've installed a 305 in my Chevy Pickup, but the temperature sending unit for the temperature gage is a larger diameter than the 305 temperature sensor. What doI do for a temperature sender?
You can put a small length of pipe in the hole and use nipples/adaptors available at the hardware store to screw the sender into the pipe. Just make sure they aren't plastic.
Paint & Body Shop moderator
