3 members (Chris's 46 / 515, Rusty Heaps, 2-Ton), 154 guests, and 3 robots.
Topics128,080
Posts1,055,950
Members48,430
#38843 05/23/2005 7:01 PM
Z
ZB3
Offline
Z Offline
My son and I have started to work on a 1952 3100. We are getting ready to pull the engine and transmission. There looks like a threaded collar on the torque tube that needs to be unthreaded but I am not sure. I have a shop manual but it does not say for the torque tube. Also what is the trunnion. We are learning as we are going. Thanks, ZB3
#38844 05/23/2005 8:12 PM
8
8 Offline
The threaded collar does not need to be removed to slide the u-joint ball back on the torque tube. The collar does need to be removed to replace the felt packing seal underneath. To pull the u-joint ball back, simply remove the 4 bolts from the rear of the transmission. If I recall correctly, you will need to jack up the back of the transmission to get the u-joint ball flange back past the rear transmission mount. Clear as mud? Once you get into it, it will make perfect sense.
The trunion is the + shaped piece of the u-joint.
I just worked on my u-joint about 6 weeks ago. I was a little nervous going into it, but came out with a good understanding of how everything works. Its not difficult. Just be observant about how it is all put together. Good luck and keep us posted.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#38845 05/23/2005 8:14 PM
ZB3,
If you search on "tube collar" in this forum, you will see a few discussions of this operation. Here is one:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=004346#000000
I think you will have to loosen the collar a little in order to slide the "ball/bell" backwards (the collar tightens the seal against the tube). Also, the ball/bell/collar will not slide backwards unless the tube is completely cleaned.
Tim
#38846 05/24/2005 3:29 PM
Z
ZB3
Offline
Z Offline
Thanks for the help. We are having fun and learning too!, ZB3
