2 members (joe apple, jmoore), 129 guests, and 1 robot.
Topics128,048
Posts1,055,540
Members48,425
#388269 03/15/2008 11:56 AM
I have a 3100. The title says 1950 but I know the doors (at least the door handles) are 1952 by the push buttons. Is there anyway I can tell if I have a 1950 with 52 doors or a complete 1952?
thanks,
The CPA, never under estimate the value;
especially when he's driving an old Chevy truck!
1947 Chevy 1/2-Ton Advance Design in the Gallery
1951 Chevrolet 3100
cowboycpa #388270 03/15/2008 12:11 PM
What does the VIN number say?
http://www.stovebolt.com/techtips/#ID
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
take a look here and see if it will help you out any
http://50chevy.freeservers.com/Vehicle_Identification.htm
Drive with Pride. mike j
family pic
dakota #388316 03/15/2008 4:08 PM
Check to see if you have the huck style brakes. I think they stopped using them after 1950. My vin says I have a 53, but I know the chassis is 50, the engine block is a 53, and the doors are older than 53.
Jim Meier #388402 03/15/2008 7:43 PM
Hello Jim,
I'm really new at this. I have no idea what a HUCK style brake is???
1951 Chevrolet 3100
cowboycpa #388415 03/15/2008 8:06 PM
The brake shoes are attached to each other(hinged at the bottom). More modern brake shoes are separate.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
54TOW #388421 03/15/2008 8:18 PM
Martin,
Look at the backing plate where the brake lines attach. Then look for the slots where you adjust the brakes. If there are two adjusting slots, one to the right and one to the left you have huck brakes. If there is only one adjusting slot you don't have huck brakes and your truck is likely newer than 1950. You should also check the vin out as suggested in the previous posts.
Jim Meier #388423 03/15/2008 8:21 PM
Good tip, Jim. I had forgotten about the adjusters.
David Colter
54TOW #388449 03/15/2008 8:57 PM
Dave,
If you give a lazy man a job to do He'll find an easy way to do it. cool
Jim
