| | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | I have a 3100. The title says 1950 but I know the doors (at least the door handles) are 1952 by the push buttons. Is there anyway I can tell if I have a 1950 with 52 doors or a complete 1952? thanks, | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What does the VIN number say? http://www.stovebolt.com/techtips/#ID Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Check to see if you have the huck style brakes. I think they stopped using them after 1950. My vin says I have a 53, but I know the chassis is 50, the engine block is a 53, and the doors are older than 53. | | | | | Joined: Feb 2008 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 81 | Hello Jim,
I'm really new at this. I have no idea what a HUCK style brake is???
Martin | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | The brake shoes are attached to each other(hinged at the bottom). More modern brake shoes are separate. | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Martin, Look at the backing plate where the brake lines attach. Then look for the slots where you adjust the brakes. If there are two adjusting slots, one to the right and one to the left you have huck brakes. If there is only one adjusting slot you don't have huck brakes and your truck is likely newer than 1950. You should also check the vin out as suggested in the previous posts. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | Good tip, Jim. I had forgotten about the adjusters. | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Dave, If you give a lazy man a job to do He'll find an easy way to do it.  Jim | | |
