| | | Forums66 Topics128,012 Posts1,055,321 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38779 01/26/2002 3:07 AM | Joined: Jan 2002 Posts: 7 Member | | Member Joined: Jan 2002 Posts: 7 | Just got a '66 step side. Seller says it is a 235 c.i. How can I find out? The VIN on the title is C1446A120975 for what that is worth. I can't find any i.d. numbers on the body. | | |
#38780 01/26/2002 5:12 AM | Joined: Aug 2001 Posts: 21 Member | | Member Joined: Aug 2001 Posts: 21 | I'm not too sure about the number but I thought they came with a 230, or 250 if it's stock. The 292 was also put in them if ordered.
Nate
If you're clean, then you're not a 'Man' If your truck is clean, then your truck is a 'Queen'.
50 3/4T Chevy until it is traded or sold 48-55 1/2T Chevy parts until they're all gone
#38781 01/26/2002 6:20 AM | Joined: May 2001 Posts: 10 Member | | Member Joined: May 2001 Posts: 10 | Robber,
Welcome to Stovebolt. WWW,Americanclassic.com has a VIN decoder on their site and you can run yours there. Although, it won't tell you what size motor you have. You need to find the number on the motor (passenger side between dist. and front of motor) to id what you have.
Good luck,
Rick
62 1/2 ton FS SB big window
With all the torque in the newly built 454, will the motor stand still and the truck spin around??
