5 members (52Carl, klhansen, Otto Skorzeny, farmallb, rick46ia), 75 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#38767 03/22/2004 3:23 AM
what pinion angle should i use on my 1940 chevy truck? i am using stock rear leaf springs,with a 12 bolt rear,running 502 bbc.thanks
#38768 03/22/2004 3:42 AM
Under normal loaded conditions , the 'U' joint works best at minimum angle .
So set the pinion to be parrallel with the g/box output shaft , under load.
This may equate to 3 deg down from parallel to the g/box shaft under no load.
The 502 BB will generate plenty of torque to twist the springs up a little grin .
#38769 03/22/2004 2:45 PM
Tommy, the pinion shaft angle and the transmission shaft angle should be the same but, not on the same plane. The u-joints need a slight off set to work properly, 3 degrees I think. The key is the same angle on both ends.
Someone directed me to randysringgrearandpinion.com when I was debating ratios. Great site for you kind of questions. Mike
#38770 03/22/2004 6:52 PM
The angle between the trans output shaft and driveshaft should be the same as the angle between the pinion shaft and driveshaft. Max 3 degrees there for reliable vibration free operation. Should have a minimum of 1/2 degree which allows the needle bearings to rotate. Zero degrees, zero needle rotation.
