| | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | I've read that an vw beetle wiper motor will bolt right in the AD trucks. Is there truth to this? appreciate conformation.
Plattelnjpichler
| | | | | Joined: Jan 2008 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 85 | Thats what mine has in it.Or thats what I was told.The little I looked at it ,It dosn't look like it was a bolt on mod,but it don't look like he needed to do anything to bad to make it fit.I can't say how good it works because I just put the windsheild in and haven't had a chance to put the wiper arms back on.But if you want I could try to get a picture, but they wouldn't be very good one's. | | | | | Joined: Sep 2003 Posts: 151 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 151 | I was told the same thing for my '46 Panel. That the VW units would fit inside the cover with no problem. I was told you may have to remove and mod the mounting brackets but if you can find soome in a local yard it would be cheaper then new units. I got 2 sets from American Classic Trucks that fit under the cover just fine.
David Just a firefighter, Cleverly disguised as a responsible adult '46 1/2 T Panel
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | They aren't quite a bolt in. Check out this link on Hotrodders.com (pages 18 and 19) The guy has documented a step by step retro-fit of one on a '53 pickup. | | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | 48 one ton ...thanks for replying much appreciated..Sepp 22...vw wiper motor...
Plattelnjpichler
| | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | blupen.....thanks for your consideration..looks like a try. thnks..Sepp 22
Plattelnjpichler
| | | | | Joined: Feb 2008 Posts: 23 New Guy | | New Guy Joined: Feb 2008 Posts: 23 | Gostrider...Thanks a lot...looks like a mod, but what isen't. Thats what makes these trucks great...much apprecited Sepp 22
Plattelnjpichler
