| | | Forums66 Topics128,211 Posts1,057,469 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38749 11/26/2002 7:15 AM | Joined: Nov 2002 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2002 Posts: 48 | I just removed my torque tube rear end and would like to take the torque tube out of the rear axel so I can transport it. Does anyone have any ideas? I have already taken out all the housing bolts but for some reason it won't come off it starts to come off as the gears unmesh when I rotate the impeller shaft but when I continue to rotate it it is sucked back together?
If you need a tool and don't buy it, you will find you have paid for it and don't have it.
#38750 11/26/2002 12:59 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Did you pull the axles out ?
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#38751 11/26/2002 5:15 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Zacacc: You need to pull the axels, then the ring gear assembly. Don't forget to remove the three set screws, they hold in the torque tube. Then you can use a block of wood and hammer on the front end of the drive shaft it should pop right out. Check out the shop manual there is a pretty good discription on how to do this. If you don't have one I would suggest that you make the investment, it's a big help. George | | |
