1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | was mounted to the floor near the high beam switch. was not hooked up but appears to have a vacuum tube fitting. http://community.webshots.com/album/562014862MZZgmtlast 2 pictures on album | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bucket, that looks like a manual windshield washer pump, a little diaphragm pump with two check valves, hope that helps. | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Yes, it looks like a foot-operated windshield washer pump. They were fairly common for a few years. You should also find a washer bottle and discharge nozzles. The bottle may be missing, but a bracket may remain attached to the firewall. The washer bottles were glass, about 2-3 quart capacity.
Harvester | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Definately the foot pump for a windshield washer.
Bruce | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | thanks guys. makes sense. the bottle, nozzles and tubing are long gone. | | |
