3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
Converting modern transmissons with electronic speedometer drive sensor is a problem when you have a good old original cable driven speedometer.
I converted an 89 T-5 5spd.(electronic speedo.) into my 47 Chevy. Did not want to mess up my perfect original Speedo.
Nevada Speedometer, Sparks, NV (775)358-7422 had the answer!
Called the "Cable X" coversion box from Abbott Interprises, INC. The unit runs from the signal produced by the transmission sensor and turns an electric motor in the box that drives the speedometer cable. Dip switches sets up the calibration. Box mounts inside the vehical on the firewall.
This thing works GREAT!
The cost was $300.00. Electronic Speedometer conversion was alot more, a long wait and would not match up to the rest of the dash.
Read about it at http://www.atrol.com/abbott.htm
Speedo Shop was the same price as the net and you get the technical support if you run into set-up confusion. Any reputable shop should be able to help out.
Hotrod6
47 Fleetmaster, Hotrod 6, 5 Speed
50 Sedan Delivery, 327, 5 Speed
Riding in the Passing Lane
Thanks. I,ve got a t-5 but haven,t been able to
use it for that reason.
1972 Chevy c10 Cheyenne Super
What will they think of next? I wonder if you can make it turn backwards, and leave it on all night!
1951 1 Ton Completed
