9 members (GRNHydra, 1955 1 Series, NAPCOStormTrpr, joe apple, Charles in CA, klhansen, DBJ71SuperCustom, dt235sd, 1 invisible), 101 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
I have installed a 67 1/2 rear end in my 50 1/2 ton. Iam using a sm420 4 speed out of a 54. The trans mount with the old inclosed drive line, does not look like it is going to work with the four speed.Is there a trans mount for the four speed that will work with the old cross member. Or do I have to go custom.
Thanks.
1 Offline
what motor are you running?
The has the same 216 that Chevy put in it.
