1 members (Southerntruck), 134 guests, and 0 robots.
Topics128,192
Posts1,057,353
Members48,469
1 Offline
here are some more pic's of the 54'. measured the wheelbase today 168" and was wondering about the 2spd rearend, what kind is it? hope to strike a deal on a GMC fwd motorhome chassis this week,located 3 of them to choose from.
Spanky will have the definitive answer, but, my guess is that if it the same as used on a 54/55 2-ton COE, it's an Eaton 2-speed rear-end with vacuum-assisted shifter.
Tim, micron, The Chevrolet's from this era had Timken 2 spd. rear axles. I've got one in a '55 1st series Chevy COE,rolling chassis, out back.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Spanky,
Did the 54/55 GMC 350 have an Eaton 2 speed?
Tim
Tim, The GMC's utilized the Eaton 1350 2 spd.(which is almost identical to the splined flange Timken 2 spd.Chevy used)& the Eaton 16600, (which used the bolted flange).
Spanky Hardy
1950 GMC 250 1-Ton
Tim's 350 has a splined flange two speed. I pulled the caps off, slid the axles out, and reinstalled the caps to tow it home.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
O.K., That would be the Eaton 1350, for Tim's COE. microns, should be the Timken 2 spd.
Spanky Hardy
1950 GMC 250 1-Ton
1 Offline
thanks! is their any numbers for positive id or something i should take picture of to help id rearend? which rear is better/more desirable?
24601
24601
Micron -- not to change the subject .. in your web shots, I'm curious about your GMC that you pulled the COE with -- I see it's been upgraded to newer wheels and tires -- what size wheels and tires are on it?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
That's Grant's (HeavyHauler) GMC, and yes he has new 22.5" wheels with 10 lugs on 8.75". I believe he is running 10R22.5 tires.
Grigg
---All pictures---
