3 members (tclederman, Bill Hanlon, 1 invisible), 197 guests, and 3 robots.
Topics128,106
Posts1,056,213
Members48,436
I have installed a 67 1/2 rear end in my 50 1/2 ton. Iam using a sm420 4 speed out of a 54. The trans mount with the old inclosed drive line, does not look like it is going to work with the four speed.Is there a trans mount for the four speed that will work with the old cross member. Or do I have to go custom.
Thanks.
1 Offline
what motor are you running?
The has the same 216 that Chevy put in it.
