2 members (klhansen, 1 invisible),
137
Mod | | | Forums66 Topics128,211 Posts1,057,473 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | I'm taking the cable and Edelbrock off my 58 Chevy Apache and putting the stock linkage and Rochester 4GC back on. Not sure how it is supposed to be bolted on there. Can somone show me a picture of the linkage on their firewall?? Thanks
I'll round off that bolt head....just as soon as I'm done strippin' this screw!
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I can try to get a photo tomorrow. They are confusing. If you buy the kit it does not cone assembled like it goes in the truck for some reason, maybe save space in shipping or the manufacture just doesn't know. If I can get a photo tomorrow I will e-mail it to you. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | on a 58 w/ 2bbl 283 [click "full size" on the right of the pic] ... I believe it's shown in the assembly manual also ... kind of hard to get a good pic when it's all up, but the 58-9 have the mounting holes on the firewall in the right place, just needs to be bolted on with the pedal end poked in the hole, then the threaded rod hooked to the carb Bill | | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | I can try to get a photo tomorrow. They are confusing. If you buy the kit it does not cone assembled like it goes in the truck for some reason, maybe save space in shipping or the manufacture just doesn't know. If I can get a photo tomorrow I will e-mail it to you. Thanks Wrenchbender. After I figured out that it was not shipped assembled like it goes on the truck I was at a loss to figure it out.
| | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | on a 58 w/ 2bbl 283 [click "full size" on the right of the pic] ... I believe it's shown in the assembly manual also ... kind of hard to get a good pic when it's all up, but the 58-9 have the mounting holes on the firewall in the right place, just needs to be bolted on with the pedal end poked in the hole, then the threaded rod hooked to the carb Bill Bill, Do you know if the linkages is different for the 2 and 4 barrel carbs? I'm guessing it would be the same, but I'm not sure. That helps. At least I know I have the vertical part and bracket on correctly. I should be able to figure the rest out. I may need to bend this sucker some.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I tried to send photo,s to the E-mail you sent but they keep comeing back. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | carb shouldn't make any difference Lucky, but yes, the threaded rod could easily be modified to fit if required
Bill | | | | | Joined: Mar 2005 Posts: 24 Apprentice | | Apprentice Joined: Mar 2005 Posts: 24 | I tried to send photo,s to the E-mail you sent but they keep comeing back. George Sent you a PM with my work email in it. Hope that works. This is a vexing problem.
