| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38642 09/12/2004 5:40 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | How tight do the lock bolts fit? Do I need a 4 lb sledge to pound them in? I have the king pin lined up in the spindle, but it is awfully hard to drive the lock bolt in. Might it be that I just don't have the strength that's needed? Do I need to get the neighbor guy?
Winona 1949 3100 5 Window Deluxe Cab
#38643 09/12/2004 5:47 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | DO you have the flat side of the kingpin facing the hole for the lock-pin? Does the kingpin have the flat spot for the lock-pin in the center (top to bottom) on the kingpin or is it more toward one end ? I do a lot of them (kingpins) and do not remember haw each one is machined (I would go nuts
#38644 09/12/2004 5:52 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Yes, I did make sure the flat spot in the king pin is in the right place in the spindle. The flat spot is centered.
#38645 09/12/2004 7:05 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | 49erGal: The flat spots have to match king pin to bolt but I'm sure you are aware of this. Lightly hammer on the lock pin if it won't budge make sure the inside race hasn't slid down just a hair.
Change mine a year ago and had to lighty tap to get them to go thru. Guarenteed you want them tight.
popcorn The Truth is Out There (Good luck and keep us posted) Ben | | |
#38646 09/12/2004 7:40 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Everything is lined up. It won't go with light tapping. It looks like the flat spot on the king pin is not flat enough? I bought the king pin set from Chevy Duty.
#38647 09/12/2004 9:04 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have a long tapered punch I drive in the hole to line up the king pin. if it is turned just a little the lock pin won,t go in very far. Dont use a bigger hammer. It should,t take much to get it most of the way & then draws up with the nut.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#38648 09/12/2004 10:04 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Everything is lined up. The race has not slipped, the king pin is centered properly as is the pin bolt. It will not go.
#38649 09/12/2004 10:18 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is there a flat spot on the lock pin? :confused: They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#38650 09/12/2004 10:27 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Time to get the vernier caliper out . How does the dia of the lock pin compare to the hole in the axle . ? Any burrs evident ? | | |
#38651 09/12/2004 10:47 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | One of the two flat spots are not deep enough. The lock pin does fine without the king bolt in, and visa versa. This is on both sides. I have switched king pins side to side and nothing helps.
#38652 09/12/2004 10:49 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Say 49ergal. I work close to Chevy Duty. If you wan,t I,ll print this out & take it by there & see what they have got to say about it. Wrench"sensitive"bender Ret. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#38653 09/12/2004 10:53 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Any help is greatly appreciated. I should've had this done last week. I've been fitzing with it tooooooooooooo long now.
OOPS! My error. I bought them from Jim Carter.
#38654 09/12/2004 10:59 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,m sorry. I won,t be able to go that way for a few days. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#38655 09/12/2004 11:17 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Thank you. I've emailed them with the problem, complete with pictures. I let you know what happens, whether it's them or me.
#38656 09/13/2004 12:12 AM | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Haven't done a Stovebolt lately, but a Furd kingpin has a tapered lock bolt slot. Try turning them upside down from their present position, and see if the taper works better. Jerry
#38657 09/13/2004 12:34 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The groove on the kingpin is not tapered. It is quite long, much longer than the pin width. The pin is round and has a flat side with maybe a very small taper to it. The pin should go in to where the threads are showing through. Then some light tapping should move it more to be able to use the threads. You don't want to hammer it hard, that would be a big mistake.
If the kingpin is off by just a few degrees, and it is tight, you can have a problem like this. The hint about the tapered drift is a very useful thing to try. | | |
#38658 09/13/2004 2:52 AM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Had everything lined up and when light taps would not work, that's when I started hollerin' for help. I tried all the suggestions, and it's still a no go.
#38659 09/13/2004 3:05 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 49erGal, how did your old pins come out, drilling or tapping? If they came out in 1 piece, it may be of interest to try them for fit. | | |
#38660 09/13/2004 4:34 AM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | I tapped them out, but they were trashed, as the "taps" were none too gentle. I do have some shorter lock bolts from a 53/54 Chevy car. Does anyone know if the circumference is the same?
#38661 09/13/2004 2:28 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | 49erGal, is there a chance that there is a slight distortion at the opening where the threaded end should emerge? To check for this, if you insert the pin backwards, that is back to front, the results should be identical.
Also, if you are very close to success, putting the pin in the freezer for a few hours may help. | | |
#38662 09/13/2004 3:24 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | I've tried them ever which way except side ways! The fit from either side is the same. I'll try the freezer method next.
#38663 09/14/2004 7:28 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | I give up on this set of king pins. I've ordered another set.
