| | | Forums66 Topics128,077 Posts1,056,014 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 52 | I have a 52 1/2 ton mounted on a 78 short bed frame. I didnt start this project, and some fabricating was done where the brake switch bracket and piece that keeps the switch depressed. Need picture of how this thing mounted please. Thanks Shelly | | | | | Joined: Dec 2007 Posts: 34 Apprentice | | Apprentice Joined: Dec 2007 Posts: 34 | I dont have a pic but as long as the switch depresses right as you push the brake pedal you should be fine. switch will be pressed when not touching the brake and not touched when brake is pushed | | |
