3 members (TexasA&M48Truck, TUTS 59, Barney1951), 84 guests, and 4 robots.
Topics128,191
Posts1,057,224
Members48,465
Junior Member
Junior Member
Hello I am working on my 1961 4x4 and the 235 that is currently in it leaks antifreeze into the oil real bad plus I just wont a little more powerit has a 4 speed manual that I plan to keep in it. What I am wondering about is what motor mounts will work for my application, also what can I do to get decent milage out of it when it is to the driveing stage of the project I am unsure of the rearend. Thanks Any help will be appreciated
easiest way to go about it would be find a 61 [or that series anyway] at a wreckers that had a V8 and scoop the mounts and anything else that's different tween 6 and 8 - for good mileage, keep it well tuned and keep yer foot outta the carb! grin not sure about the rear gears, as w/ 4x4 I understand ya gotta have the right ratios front and rear [same?]
