1 members (Alex52),
136
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 23 Apprentice | | Apprentice Joined: Dec 2007 Posts: 23 | Could anyone come up with the distance from the bottom of the frame under the cab to the pavement of a stock height 56 TF 1/2 ton? I'm working on a 56 3/4 ton that will have a 79 Firebird front subframe and rear end from the same car.
I bought the 56 as a basket case and have no way of establishing the 'normal original' ride height.
Any help or ideas appreciated.
Bob | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I got about 18" on mine. With the front clip you're planning to use, stock hight won't be easy to acheive, unless you offset the front stub to compenasate. The axle centerline is much higher on the Firebird frame than it is on a truck frame.
Bill Burmeister | | | | | Joined: Oct 2007 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 58 | I'm changing springs so just made this measurement. My 58 Burb is right in line with what Longbox55 has. Before changing springs it measured 17.5 inches with fairly tall 235/75/15 tires. | | | | | Joined: Dec 2007 Posts: 23 Apprentice | | Apprentice Joined: Dec 2007 Posts: 23 | Thanks for the replies and the info. My plan is to use a 2" spacer between the bottom of the TF frame and the rear horns of the TA subframe. Should look something like this: (not mine) http://img.photobucket.com/albums/v246/rbachman/FiftySix%20Chevy%20PU/TF80TAClip.jpgIt appears the top of the TF frame is flush with the top of the TA subframe. Bob | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That looks like it will help some, but it'll still sit lower than stock.
