Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Sedgewick, Charles in CA, crenwelge, UtahYork, TexasFarmTruck, Mike1933), 161 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#38589 01/04/2004 1:07 AM
I messed up and threw away the banjo bolt when I rebuilt the front axel of my '59 3100!
Does anyone know the Wagner part # or where I can get a new fitting ?
The brake hose fits in the middle and the two 3/16" linse fit into the ends. It's on the driver's side frame rails and connects the two front brakes to the master cylinder.
I feel like a real dunce. The bolt was in a bag with the old hoses and I cleand out the shop and threw them all away!
HELP!
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#38590 01/04/2004 8:23 AM
Hey neighbor, take the other side off for match up purposes and go over to or call up Antique Auto Supply 817 275-2381 in Arlighton at 1225 Colorado Lane - in a warehouse. I got a banjo block for my 59 1 ton from him. He's got a bunch of stuff in a box and can usually match up if you bring the old bit with you (or similar).
or email me, I looked in garage and I might have a banjo bolt that will work, if that's all you need. (not sure from the post if you just need the bolt or the whole block) U in Erath county? Bit of drive to Garland.
#38591 01/04/2004 11:47 AM
Thanks Irwin! All I need is the bolt and new copper washers.
I'm in Denton county by lake Lewisville.
We need to get the other North Texas Stovebolters together some day.
drop me an email [email protected]
#38592 01/05/2004 6:25 AM
Try Wagner part # F5727 has two 3/16 connections and a 19/32 hole through to mount to the end of the master cylinder. Let me know if you need the part # for the banjo bolt with or without 3/16 fitting in the end fitting.
#38593 01/05/2004 6:39 AM
Chevrolet didn't use that many different copper washers and banjo fittings. I went to the website for Danchuk Chevrolet (55-56-57 car parts) and found a banjo fitting and bolt that works on my 37 pickup with some slight alteration. Try: www.danchuk.com or 1-800-854-6911.
Good luck!
#38594 01/05/2004 11:06 AM
#38595 01/05/2004 1:53 PM
Guys,
The fitting (or rather just the bolt) I'm looking for is the three way fitting that is on the driver's side that connects the 3/8" wheel cylinder hose to the 3/16" line from the master cylinder and then to the 3/16" line that goes to the passenger's side.
It's for a '59 3100 truck.
everything I've seen so far is the fitting at the end of the mastercylinder which I don't need.
HELP!
#38596 01/05/2004 5:18 PM
What you need is the fitting off the rear axle should work as well but i don't have a part # for that one.
#38597 01/05/2004 7:17 PM
You should be able to get that tee at a parts store locally. I'd take the hose with me to be sure it fits, the other fittings are standard size.
Fred
52 3600
69 C-10
