1 members (JW51), 98 guests, and 3 robots.
Topics128,055
Posts1,055,782
#38579 04/25/2002 5:55 PM
I just broke off the bleeder valve in my 42's front brake cylinder. I tried heating and cooling and easy-out etc. but had no luck. Just basically tore up the valve. Is there any way I can drill out the old valve and tap in new threads? Will I need a special drill bit (like a recessed bit)? Will a new valve seat properly if I re-drill and re-threat?
Chris Simmonds
1942 Chevy 3/4 ton
#38580 04/25/2002 6:01 PM
I think the threads are UNF threads. The seat is past the threads a little way, so if you don't nick it and use a bottoming tap for the last few turns you should be fine. What size brake cylinder is it? If it is the same as a 1950 huck cylinder I have a set of decent cores I could part with, ping me offlist. I just removed them from my truck, and I can hone them for you. You will need to kit them. To check to make sure on the threads, buy a new bleeder and check the tap against it. Those bleeders can really stick in there. Be careful using heat so you don't warp the cylinder.
Paint & Body Shop moderator
#38581 04/25/2002 8:21 PM
i always put antiseze on brake bleeder screws and that works to avoid that
put antiseze on all most all bolts and the guys that have to remove them again will thank you
i thinkzz traveling along at terminal velocity will soon wear a body out.
i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#38582 04/25/2002 8:41 PM
chris42pu,
This is "closing the gate after the horse is gone" but, I've found that approaching old bleeder screws with a GOOD SIX-POINT, 1/4 drive socket (SAE or Metric, whichever fits best!)and GENTLY rocking, first "tightening", then "loosening" ever so slightly, until you feel the screw free-up.
(A good soaking with PB Blaster beforehand helps.)
Usually, the first "tightening" action breaks the screw free, and it loosens-up pretty good.
I 've had good result with this method, but a good part of its sucess is contingent upon your own ability to sense when a bolt about to snap-off; having broken many in my lifetime, I've learned to be careful.
If someone's already round the hex off the screw, you can try the same approach with a GOOD pair of Vise-Grips (works easier with the cyl in a good vise); the screw is usually "toast" by this point, but replacement screws aren't hard to get.
Good luck!
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#38583 04/26/2002 5:51 AM
Did you check with the parts store to see if you can get a new cylinder? 42's are older than I know about on that stuff, and broken bleeders are a real PITA to get out.
Fred
52 3600
69 C-10
#38584 04/26/2002 7:55 AM
I am a big fan of setting a nut on the broken part, and mig welding it to the nut through the hole in the nut. Then use a socket on the nut to back out the whole assembly. The mig welder has helped me recover from a lot of OOPSes.
David
#38585 04/26/2002 11:30 AM
Bleeder repair kits are readily available at good parts stores. Drill it out oversize and re-tap to typically 1/8" or 1/4" pipe. The repair bleeder contains the seat so no worries of nicking it. Works well.
#38586 04/26/2002 7:27 PM
Thanks everyone for the input and great advise on how to avoid this in the future. However I have been told once never to use antiseze on bleeder vavles. I am not sure why...maybe to prevent it from entering the cylinder. And thank you chuckthetruck for the specific information on repairing the cylinder I already destroyed grin
Chris Simmonds
1942 Chevy 3/4 ton
#38587 04/26/2002 10:03 PM
when you use anti on the threads it prevents air and water to settle and rust the bleeder screws again eek
#38588 04/27/2002 6:37 AM
I have been in the same situation with wheel cylinders before.I have found that replacing them solves many problems.once you have figured your time in rebuliding a worn part and taking the chance of crashing your cool ride,not to mention possibly hurting or killing yourself or someone else,,,,,,,,,I`ll replace the cylinder! eek
However, if it is in good shape, I will rebuild it! cool
