5 members (carbking, TexasJim50, baldeagle, Hotrod Lincoln, 1 invisible), 91 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
#38570 11/03/2003 2:21 PM
Can anyone describe or better yet attach a photo of the oil distributor side of a 216 showing how a oil filter is hooked up. I thought I took a photo of this before I tore down my engine but cannot find it and cannot figure out where the lines run and where the oil pressure line to the dash attaches to the engine. Thanks. Robin Wise
#38571 11/03/2003 4:21 PM
Though this is a 235 maybe they hook up the same? Not the best shot but I happen to have it on file. The side hose goes towards to rear while the bottom hose heads south towards right above the oil pan. The cannister itself is bolted to the manifold via two "U" bolts.
[img]http://www.cmaynard.com/Truck/chevyeng.jpg[/img]
Craig
#38572 11/03/2003 4:43 PM
There is something called an oil gallery on the side and I think there has to be a T fitting off of this and one hole of the T holds a line from the filter cannister and one may be the oil pressure line to the guage on the dash, but I can't visualize how this hooks up.
#38573 11/03/2003 5:42 PM
Here, maybe this is what you're after....
http://community.webshots.com/album/97772002rzpbkC?208
Craig
#38574 11/03/2003 5:51 PM
Oh yea. Thanks cmayna
#38575 11/03/2003 6:34 PM
Here's a picture of the fitting locations from another angle:
[img]http://home.nycap.rr.com/lederman/images/blockoil.jpg[/img]
#38576 11/03/2003 7:51 PM
Good pic and nice job on the block! The FROM filter inlet (see previous pic) goes to the bottom of the oil filter with a short hose, the long hose goes between the TO filter outlet and the side of the oil filter.
I lost the T connection part and had to buy a new one (from the hose shop that made my oil lines). I couldn't find one with the same fitting as my oil sensor, so I had to cut the line and add a different compression fitting.
#38577 11/03/2003 8:13 PM
My 216 is somewhat different from the pictured posted and I may have to get out my camera and figure out how to post a photo here. There is what the manual calls an oil distributor which is right between the two freeze plug holes in the block. This has an outlet (threaded hole) in it. Then there are the inlet and outlet holes pictured above. The guy that rebuilt my engine ran a small copper tube in a loop shape from the outlet in the oil distributor to another threaded hole in the block. I don't remember this when I took the engine out. Anyone with a 216 with an oil filter? Would appreciate some help
