5 members (baldeagle, ShopRag, J Lucas, Wally / Montana, CuzzFuzz), 52 guests, and 12 robots.
Topics128,020
Posts1,055,345
Members48,419
#38550 03/26/2005 4:45 PM
I've just purchased a 39 with a 4 speed that really growls. After having 5 advanced designs I'm not sure what is normal. Lucas and STP don't seem to help. The truck has a '59 235 which came with the original 4 speed trans set up for an open drive line. If I use that trans what is a good rear end that I can swap and still use my 16" wheels? Limited slip would also be nice.
#38551 03/26/2005 5:25 PM
X
X Offline
Are you saying the trans. is the original '39? If so, those early pre-'48 4-speeds had straight cut gears, so they are going to be noisier than the later 4-speeds with helical gears. I don't know how much noise is normal either. Could be bearing problems, too.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#38552 03/28/2005 4:48 AM
Thanks Curt - I think I'll keep the non syncro 4 speed. My '48 advance design 4 speed shifts like a dream compared to the '39 4 non syncro but I like the challenge of hitting the gears with a smooth double clutch. I used to drive semis in the 60's and my first rig was a B-61 Mack tractor which required shifting a 5 speed gear box and a 2 speed axle at the same time. It took some time to master; if you missed a gear on a hill you had to start over. Once I mastered the trans it was a plesasure to drive. Thats what I like about the '39. (and the old lady never asks to borrow you're truck)
