5 members (Hotrod Lincoln, baldeagle, Otto Skorzeny, TooMany2count, Shardean), 125 guests, and 3 robots.
Topics128,024
Posts1,055,392
Members48,422
#385042 03/08/2008 1:18 AM
can anyone help me with identifying my truck? the serial # is
4008 CJ 1383E it is a GMC 4000, max. GCW 35000. it has a 2 speed axle, and torsion bar front suspension.
47chevy6400 #385049 03/08/2008 1:45 AM
You have a 1962 GMC, made in Oakland, CA. The E on the end stands for the GVW, but I don't have any listings for that handy right now, but it is medium size truck. The GCW is the Gross Combined Weight, but listed next to that will be the GVW (Gross Vehicle Weight). List that for us if you would, but I'm going to guess that it is around 19,500.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
are cab parts and doors the same as pickups and is it a 1.5 ton or a 2 ton
47chevy6400 #385085 03/08/2008 3:02 AM
The doors are the same. The cab is basically the same, the floor, mounts and maybe a few things under the dash will be different, but I've never compared the two piece by piece.
It's probably considered a 2-Ton, but that can be determined better when you verify the GVW for us.
GMC 9500 Fan
Detroit Diesel Fan
the plate says
GMC TRUCK & COACH DIVISION PONTIAC, MICHIGAN
SERIAL NUMBER 4008 CJ 1383E
GROSS H.P. 165 AT 3800 R.P.M.
NET H.P. 148 AT 3800 R.P.M.
Max.GVW 19500lbs. Max.GCW 35000lbs.
47chevy6400 #385278 03/08/2008 1:45 PM
It would be considered a 2-Ton.
GMC 9500 Fan
Detroit Diesel Fan
