8 members (delky, val, UtahYork, Otto Skorzeny, mason86, Bill Hanlon, Woodcmiami, 1 invisible),
60
Mod | | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | can anyone help me with identifying my truck? the serial # is 4008 CJ 1383E it is a GMC 4000, max. GCW 35000. it has a 2 speed axle, and torsion bar front suspension. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | You have a 1962 GMC, made in Oakland, CA. The E on the end stands for the GVW, but I don't have any listings for that handy right now, but it is medium size truck. The GCW is the Gross Combined Weight, but listed next to that will be the GVW (Gross Vehicle Weight). List that for us if you would, but I'm going to guess that it is around 19,500.
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | are cab parts and doors the same as pickups and is it a 1.5 ton or a 2 ton | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | The doors are the same. The cab is basically the same, the floor, mounts and maybe a few things under the dash will be different, but I've never compared the two piece by piece.
It's probably considered a 2-Ton, but that can be determined better when you verify the GVW for us.
| | | | | Joined: Feb 2008 Posts: 207 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 207 | the plate says
GMC TRUCK & COACH DIVISION PONTIAC, MICHIGAN SERIAL NUMBER 4008 CJ 1383E GROSS H.P. 165 AT 3800 R.P.M. NET H.P. 148 AT 3800 R.P.M. Max.GVW 19500lbs. Max.GCW 35000lbs. | | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | It would be considered a 2-Ton.
